Upgrade plan
Thaben
Can I upgrade my plan right away? The only option I see when trying to upgrade is to wait until the next cycle (payment) for my new plan to kick in.
7 REPLIES 7
Thaben
I really appreciate your help, I didn't top up my account before I was trying to do the upgrade and the 'change plan now' option was not there. Thanks to you, I have figured it out now.
kselmak
To renew early (switch to the same plan doesn't work) you can contact moderators. To switch to any other plan you can do it manually, but as others pointed out you will not be reimbursed for unused portion.
popping
Yes, you can upgrade your plan immediately.  Please note that there is no refund of the unused days of your current cycle if your change your plan immediately.
If you decided to upgrade you plan at your next renewal date, you can buy $15/1GB data addon and/or $5/500 minutes addon get you through the remaining days of your current cycle  Addon minutes and data do not have expiry date.  Any unused minutes or data will be rolled over to the next cycle until all are consumed.
Triguy
You can change your plan immediately but then you would lose any unused minutes/texts or data.  It recommended to change on next renewal date.
https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
gblackma
Yes you can @Thaben . Use this article on how to do it https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
Stay safe
If it's because of data, I would consider this $50 hybrid plan. You can also call the US from within Canada for free.
JoyLuck
You can upgrade right away, but you will not receive any money back for your old plan.
iliketotalk
@ThabenHi iF you upgrade your plan right away you will lose what you have left in this cycle Since this is a prepaid plan
