Updating my plan
CF2024
I want to update my plan to an International plan. Data within Canada and US, unlimited calling Canada and US wide. With this plan, am I able to travel into the US and not be concerned about adding anything more for roaming?
@CF2024 wrote:
Does it matter when I make the switch? Should I wait until just before the billing cycle renews, or can I proceed anytime?
Schedule the change ahead of time. Doing otherwise will end up costing more as you would lose the maounts paid for the plan that you already have if performing an immediate plan change.
CF2024
Lalaraff
Hi.  I live close to the border and travel over to US often.
 I switched to this plan and have no problem.  No more prompts at the border to be able to use my phone over there and no extra roaming charges.
CF2024
Thanks for the quick reply
Yes, the plan includes roaming while in the US.  Please note that roaming is only included in the US.  Despite it being labelled as an itnernational plan, roaming isn't provided anywhere else.
@CF2024  Yes that correct the CAN/US plans have roaming built into it . Call to and from each country using talk text and data in either country . No need to buy anything else or worry about any surprise bills
