can't merge calls during a conference call
AW4ever
I can not merge the two parties I am calling in a conference call like I used to.  This happens after I changed my plan
2 REPLIES 2
slusagm
not all model of phones can do Conference call (although most do)
and you did this?
  1. Once you’re on the call, tap the Add Call option (the ‘+’ icon)
  2. The other person on the line will be put on hold while you add the second person. You can add the new party by selecting a contact or by entering a number manually
  3. When the new party answers, tap the Merge icon to connect all three people on the call
HI @AW4ever
if it works before but not now, start with a Reboot and then Reset Network settings
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
