5 hours ago
Can you phone u s. to can, and can. to u .s.?_-
an hour ago
You can use it in both countries to call to and from talk text and data . Just remember when in the US to have data roaming turned on in phone settings . Also set your network to 4G/LTE not 5G and make sure your connected to T mobile or AT&T some have also confirmed that Verizon works in some places so just be sure to try all 3 and use what works best for you.
2 hours ago
Yes, Canada-US plan including all the call between Canada and US, you can use the phone call, data and text in US like Canada.
3 hours ago
hi @Derreclair
yes it is included
so, you can call Canada and US from both Canada and US , you can use data in US
