"Authentication Unsuccessful" Error Message
MarkW709
When using the Public Mobile app, I get the following error message. Does anyone know how to fix this issue. It restricts my ability to fully utilize the app, particularly when travelling
9 REPLIES 9
@MarkW709 wrote:
Hello everyone, This problem was resolved but I'm honestly not sure how. It took several days and I thought the case was hopeless and then, all of a sudden, everything works. I don't know if it just required a few days or it it was something that I had previously actioned, thanks to your suggestions and help.
I appreciate this community!
I can readily replicate that error message. The site usually just needs to be loaded again.
MarkW709
I do not believe that contacted a customer support agent is required, nor do I believe that this is something that a cusotmer support agent can fix.  The Public Mobile Community website will sometimes do this immediately after logging into it or if switching from desktop to mobile view (or vice versa).  The fix usually involves some combination of simply refreshing the page by using methods such as pressing F5 or by using the reload icon in a mobile browser.  Clicking on the avatar icon/login icon in the top right should also fix this.  In some cases, all that is required is clicking on the "hamburger" menu icon and choosing "Community" to tell the Community main page to load again.
@Handy1 wrote:
@MarkW709  Try clear app cache or uninstall the app and re install it and try again . Can also try website instead with new web browser window and try incognito mode /private mode or from a buffet device even . If still same then
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
That's not the app being used. That's the Community website.
MarkW709
Thank you
MarkW709
Thanks for the suggestion, but I've tried deleting cache in my browser and I've deleted the app and reinstalled it. The same thing happens.
As for submitting a ticket, I'm unable to do that because I can't be authenticated. It's a real catch-22
hi @MarkW709
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
