11-19-2024
12:58 PM
11-20-2024
02:14 AM
computergeek541
Hi, I just subscribed a plan, and purchased a SIM card. However, I need the SIM card by this Thursday and I am not able to get it. Can I switch to eSIM without a physical SIM card?
11-20-2024 09:52 AM
It is an amazing day! I received the SIM card within one day! thank you Public Mobile!
11-19-2024 01:14 PM
@ashes_to_ashes You might want to contact support anyways and ask if then willing to give you credit for buying new SIM card because if the Canada post strike delaying orders . Good to have a spare one laying around anyways incase you lose or damage yours or to give to a friend and use your referral code to save even more . Just a thought be sure to save your receipt for new SIM card if they agree
11-19-2024 01:01 PM - edited 11-19-2024 01:11 PM
@ashes_to_ashes You could just go buy one from Telus / Koodo store today and avoid using eSIM or order from Amazon $4.99 there . But if you want to switch to eSIM you will need supports help
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
11-19-2024 01:00 PM
you can instead get a physical sim card faster (but you need to pay)
Buy a PM physical sim card form Telus or Koodo store (same day) or via Amazon (within 2 days with Prime):
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
or if you really want to change to esim, you need to ask help from support agent. Please submit by direct message:
