06-05-2022 10:09 AM
06-05-2022 11:22 AM
This is usually a carrier lock issue that can easily be resolved by contacting the original carrier to get the code from them, if it is a sim card lock, follow the steps in the first post above
06-05-2022 11:09 AM
@john25 did you upgrade your phone or updated your phone with a new OS update?
Was this phone ever used on PM network before?
Or you use SIM PIN before and need to enter the PIN every time you reboot the phone?
06-05-2022 10:27 AM
Hi are you saying you have a new used phone if so it could be locked to a previous carrier, they would need to unlock it please tell us what is your exact message?
06-05-2022 10:18 AM
Did a message pop up on the new phone? What is the wording used? What brand of phone?
06-05-2022 10:14 AM
if it is the SIM card puk you are looking for , you can open ticket with this direct link :
