02-20-2023 02:21 PM
Hello I had to get a new public mobile sim card I put the new one in because my old phone with the old sim card ade not retreivable due to damage. I suspended my acvouby and got my new phone today, updated the sim card and reactivated my account and I can only recieve texts and cant send them. Am I missing a step here?
02-20-2023 11:04 PM
@jjt0227 - does your calling in/out and data work?
Perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
02-20-2023 02:54 PM
Depending on what kind of device being used, could this be an RCS -related setting?
i.e. iMessage vs Chat being on or off?
02-20-2023 02:51 PM - edited 02-20-2023 02:54 PM
@jjt0227 Can you try SIM card in another phone and see if services are working properly and or just take sim out and reseat in in the SIM card tray and push in and rebbbot device
adding. My screen shot is from mobile device just to show you tabs of where you need to find specific services but the SIM card sale needs be done on lc only … could be a provisioning issue in which case you need support to reset your account possibly
Watch for reply top of page to the
Right ( envelope image )
02-20-2023 02:48 PM
I cant find that screen at all. My new sim is corewct as well. Says my account status is now active but still can only recieve texts but wont send them
02-20-2023 02:36 PM - edited 02-20-2023 02:38 PM
Try logging out of self serve, then clear cache and cookies, then log back into self serve.
Under the Profile tab, hover over (or tap if on mobile login) the SIM card details and confirm the new SIM card number is, in fact, registered there.
02-20-2023 02:24 PM
@jjt0227 You need so this in a computer only and do SIM card swap
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
02-20-2023 02:24 PM - edited 02-20-2023 02:25 PM
@jjt0227 So you Resumed service if you put the account into Lost/Stolen mode? Try rebooting or toggling airplane mode on/off. Might need a couple of reboots.
