Unregistered SIM card
Vikingred
  • Anyone having trouble with their SIM card lately? Just recently my service stopped working and yes I have contacted support. Any of you ever come across this problem?
8 REPLIES 8
Vikingred
Everything works. Account is active,  so no it's not the account
darlicious
@Vikingred
Did your autopay fail? Can you confirm you have active service by logging into your self serve account? Or by calling 611 from your phone?
Vikingred
Waiting on tech support for an answer
Vikingred
Tried all that and still doesn't work
@Vikingred
It is very rare but can you tell us what your issue is?
Yummy
Nope, SIM works as expected...
HALIMACS
Not very common, @Vikingred
Sometimes, the account needs to be reprovisioned, however that is rare.
Also, sometimes a gentle cleaning of the gold contacts on the SIM card, with an eraser or alcohol on a swab, ensures a clean contact between SIM and device.
If this recurs, try the SIM in another device to see if problem continues...
Hollister
@Vikingred
While waiting for an agent try this:
Reboot phone
Reset network settings
Reinstall sim card
Try sim in another unlocked phone
