Unknown Data Usage
LCKC
I put my phone on airplane mode every night before I go to bed. But there are plenty of mysterious data usage every 3 or 4 days in the middle of the night like 4am.
Some data are like 41.55 MB .....
Need resolution ASAP
@LCKC
 PM does not update the data usage constantly.  In fact, it only update it twice a day.  So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  So, your morning usage use see does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
dust2dust
The timestamps are not useful.
Here is one day of my usage. I looked at the time when I turned on data twice. Around 9am pacific and around 4pm. The smaller number is the earlier usage.
@LCKC
PM update your usage twice a day. Middle of the night and midday.
