Data usage not getting updated
Damon3
It has since being a month, but on the main page of the app, my data usage still shows last updated date from 1 month ago. Is there a setting I need to do to get it updated?
Chalupa_Batman
Hey @Damon3
A couple of things. Make sure the app on the phone is updated. Second, try "Swiping Down" to refresh the page. Worse case, if it's an Android, go into the app settings and clear the cache and then data. Then restart your phone. Log back in and it should be updated.
hi @Damon3
maybe just browser or app cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again.  If using app, drag the screen down to force a refresh , or logout from the app and log back in
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
TheSterlinger
@Damon3 hey, if you are using iphone, you have to delete the app and reinstall again to update data.
If using the website,  just clear browser cache and login again. I
