United States Plans
10-15-2024 09:52 PM
I will be in the US till March 31. What is the best plan for my phone. I need to be able to text, talk and have good data.
Add-Ons
10-15-2024 09:54 PM - edited 10-15-2024 09:56 PM
depending on your data requirements, there are currently 3 or 4 Cdn / US plans that may work for you. Make sure you have a volte enabled cell that's on PM whitelist of volte enabled phones.
clipped from PM Help Files....
10-15-2024 09:54 PM - edited 10-15-2024 09:54 PM
HI @057559
choose one of those Canada-US plans here
https://www.publicmobile.ca/bc/on/plans
the $30 -20GB is a very good deal if 20B is enough for you
if you want more data, just pay $5 more, $35 for 50GB
