Undelivered SIM card shipment
JulioS
  • I ordered SIM cards but they weren’t delivered?
How do I get them?
@JulioS
When did you order the PM SIM? Canada Post might take up to 2-3 weeks for delivery depending on where you live.
If you are in a hurry, go to your local London Drugs or Walmart. Sometimes they will have a promo and will give you a free PM SIM if you get them to activate the SIM for you.
You can order one from Canadian Cell Supplies at $4.99.
Sunnymeowc
check near by public mobile store or any retailer like wow mobile or telus or koodo store they do have the public sim cards
HALIMACS
@JulioS
If you need them quickly, proceed to a local Walmart or London drugs or other mobile shop that may sell Public Mobile SIM cards.
Just tell them that you lost yours and you need a replacement - otherwise they may be hesitant to sell you one without you allowing them to do the activations for you.
You should be able to get them for around $10 each in store.
If you're in the Toronto area, Canadian Cell Supplies also provides them for cheaper.
HI @JulioS   How long you have ordered?  I think people now reported that they receive the SIM within a week
To check the status, open a ticket with PM Support,
click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
  1. Type: did not receive my sim card
  2. Then click "Contact Us" ,
  3. and then click "Click here to submit a ticket"
  4. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
BeachNBeer
@JulioS  How long ago did you order?. It could take 2 to 3 weeks to receive.
Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
