12-17-2022 11:06 AM
I have 250MB of data, however I am unable to use it even though Mobile data is ON. Please have a look at this data issue. My account is Active and Incoming/Outgoing phone call is working well.
12-19-2022 09:09 AM
Here's a thread from a few years back that might help.
https://productioncommunity.publicmobile.ca/t5/Get-Support/No-Data-on-my-phone/m-p/297220#M147220
12-19-2022 09:06 AM
I personally have not had it happen but I'm thinking that it must be an account issue as many things in the phone have been tried in order to rectify it.
12-18-2022 04:55 PM
What did customer support fix?
12-18-2022 01:53 PM
Sounds like you might need to have customer service reset something.
12-18-2022 06:48 AM
@darlicious wrote:That's the first I've heard of that....but that's not surprising as my computer game is weak. Was your Asus running 8.1?
Yes, I think so.
12-18-2022 06:43 AM
12-18-2022 06:31 AM
@darlicious wrote:I strongly suspect this is an APN issue if you have been unable to use your mobile data. Can you send/recieve MMS?
If you have an iPhone you will need to connect to wifi or iTunes and check for software updates and then update the carrier profile.
If you an Android phone you will need to edit the APN. There are a few slightly different APN'S that can be used for public mobile. If your edit settings are greyed out you may need to upgrade your OS to be able to edit the APN. If you are unable to upgrade your OS then there are other options to get the correct APN on your phone....
Try adding the following APN and then tap SAVE.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect.net/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
I used have a Asus phone that can't edit APN or create APN and the phone didn't match PM APN settings. So I googled find a software that can create APN and I installed at phone.
12-18-2022 06:03 AM
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
MMS proxy
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
APN protocol
IPv4
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
12-17-2022 12:02 PM - edited 12-17-2022 12:24 PM
Does the status of your 250mb in My Account, look like this?
12-17-2022 11:56 AM
Wwwwwhhaatt? My roaming has been off for the last 3 years and data works.
12-17-2022 11:31 AM
Check on your account is you still have all 250MB. Maybe you used them all already. If you keep Data on apps might take advantage of open Internet door and use all your data.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-17-2022 11:27 AM - edited 12-17-2022 12:17 PM
12-17-2022 11:25 AM - edited 12-17-2022 11:27 AM
@hycm53- Interesting guess. But not if they're on the $15 plan and in Canada. But we'll see what they say.
Adding - @drdas0303 - that was after clicking on the little refresh icons underneath? And did it ever work? If not then yes check out the APN suggestions mentioned. Do you have an iphone or an Android?
And was that roaming 250mb or the $15 plan and you're in Canada?
12-17-2022 11:24 AM
It shows 0 MB used.
12-17-2022 11:22 AM
@drdas0303 wrote:I have 250MB of data, however I am unable to use it even though Mobile data is ON. Please have a look at this data issue. My account is Active and Incoming/Outgoing phone call is working well.
Did you turn on roaming? If not you need turn it on.
Check your phone APN setting:
12-17-2022 11:08 AM
Hi @drdas0303 it worked before or it never work?
you can check the APN settings first
or an easier way is to select Reset All Network on your phone but this will reset your WiFi and you need to join the WiFi back
12-17-2022 11:07 AM
Did it ever work here? Maybe you used it all. Can you log in to your account? After clicking on the little spinner refresh icons lower down, does it show a red bar and all used for your data?
