11-24-2022 08:25 PM
I'm currently unable to use data on my mobile since yesterday. My current usage for the period ending Nov 30 shows its only 795.52 MB used out of 1024MB. In fact I received a text message yesterday morning that I have consumed 100% of the data for the period. Anyone know what could be the issue?
11-25-2022 12:18 AM
Listen to the text. You've used all your data. It shows incorrectly when you login because PM's website is crap and shows cached info. Use Incognito Mode for an accurate view of your remaining data.
11-24-2022 10:11 PM
HI @ajithpl313 it is true there is a delay with data showing up on Data usage page. usually 12 hours.
But usually the add-on usage showing on the front page is accurate with very little delay
So, you did use up your data. You can buy $15 for 1GB data addon, or you can open ticket with PM CS agent to have an early plan renewal. You can also make a immediate plan change yourself, without the help of CS agent, but you need to change to a plan different from what you have now
11-24-2022 10:06 PM
Thanks...the data usage now magically tuned to 1024/ 1024 used when I checked now! probably it took the portal over 24 hrs to update it.
11-24-2022 10:02 PM
HI @ajithpl313
i think it is time to open ticket with CS agent and have them confirm
To open ticket, at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
11-24-2022 09:49 PM
Yes, I tried from private browsing mode form my mobile as well as laptop..still showing same data usage of 795MB yesterday and today.
11-24-2022 09:47 PM
I was checking it yesterday and today and the data usage remained the same at 795 MB.
11-24-2022 09:47 PM
@ajithpl313 wrote:The usage is all within limits. Public mobile send me a text message that I have used 100% data and it stopped working afterwards but my account shows I have used only 75% data.
HI @ajithpl313 but did you use clear cache and restart browser to check?
or use Incognito mode
If you don't check it that way, you might not get the right usage
11-24-2022 09:46 PM
11-24-2022 09:43 PM
No such data limit set. But was wondering why Public mobile send me a text message that I have used 100% data and it stopped working afterwards.
11-24-2022 08:54 PM - edited 11-24-2022 08:55 PM
Could also be possible that you have a data limit set on your device.
Check under your devices cellular/ data settings for data limit options.
11-24-2022 08:45 PM
Might also be best to check your data settings to see what app had used the data to identify any background data usage, turn off data for that app.
11-24-2022 08:27 PM
