09-06-2024 12:33 PM
I have recently joined public mobile. I haven’t sent a message or text to Android phones since then. I have no issues with iPhone (blue speech bubble) but can’t send any messages to Android phone (green speech bubble).
03-04-2025 01:30 PM
HI @Resiiscool
make sure iOS and Carrire Profile both updated, then toggle off Send Text Message on the iMessage settings
Reboot phone, then Reset network Settings. Go back to the iMessage settings to enable Send Text Message and try
03-04-2025 01:00 PM
It is an iPhone I didn’t see your earlier post
03-04-2025 12:54 PM
@Resiiscool Is this with an iPhone? If so have you tried the suggestion I made earlier in this thread?
03-04-2025 12:50 PM
I did all of that. Nothing new
03-04-2025 12:11 PM
HI @Resiiscool
Make sure your iOS and Carrier Profile are both updated, then Reboot and click Reset network settings
03-04-2025 12:03 PM
Hi, I just switched to Public and having the same issue. What did you do to resolve it?
09-06-2024 03:27 PM
@Meow wrote:If you use NATIVE Android app then everything works as expected.
If you are using 3rd party to handle your SMS/MMS you have to figure out how that works...
The customer is using an iPhone device.
09-06-2024 01:24 PM
@APR_09411009 Assuming you have the SMS toggle turned on, go to Settings - Messages - Send & Receive and make sure your phone number is checked there.
09-06-2024 01:21 PM
09-06-2024 12:41 PM
@APR_09411009 , you need to enable SMS as the default text format instead of iMessages.
