04-27-2022 02:44 PM
04-29-2022 01:18 PM
@Eugeniopino wrote:Started today
@Eugeniopino - do you have an iphone and use only iMessage?
If so, check that you have data left remaining on your plan under the overview section in your self serve shown below. If the line item does not exist that means you used it all up this particular cycle.
If this is your scenario, go to your iphone settings and enable both SMS and MMS options. Then texts will go in/out without the need for data or wifi.
04-27-2022 03:26 PM
Lots of recent posts on this, may just be a temporary outage. If you can fill us in on the blanks above, the community would have a better idea.
04-27-2022 03:22 PM
Are your other services working? Calls? Data? Check for an outage in your area. If there is no outage reported try the following:
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
04-27-2022 03:11 PM
Known outage shown at Telus
https://productioncommunity.publicmobile.ca/t5/Get-Support/FYI-Text-Outage/td-p/817074
04-27-2022 02:46 PM
@Eugeniopino which area, province and city, you are at? There seems to be 2 more complains about text today
you tried reboot your phone? and you were sending sms , not iMessage or RCS?
