08-08-2023 01:25 PM
I have another phone number with public mobile. I interchange between this sim card and another sim card with another phone number.
I recently lost that sim card. I am unable to login to public mobile since I am unable to receive the one time passcode that is text to that phone number.
I thought I would purchase a new sim card, login to my account and change the sim card associated with that account.
How can I do this? Please help! I also need to update my credit card information and I am worried the auto-pay will not go through.
Thank you
08-08-2023 02:17 PM - edited 08-08-2023 02:18 PM
But - this is an issue (lost phone/SIM) that needs to be improved. Maybe an Authenticator app, or something. Maybe a live chat option for just lost phones, or even go into a Telus/Koodo store with govt ID
08-08-2023 02:15 PM
@smp999 did you try the incorrect OTP trick as stated above?
if still does not work, you will need support to help then
08-08-2023 02:13 PM
I tried this yesterday for a family member - the Email option was not available - tried to resend code 3 or 4 times. Only SMS and voicemail options
08-08-2023 01:37 PM - edited 08-08-2023 01:37 PM
you are correct, you need to login My Account and go to Profile page and change sim card there
To login My Account, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If no email option still, Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
