Unable to create account
Racerz2009
I selected a number but because of some technical issue , the eSIM could not be installed . I don’t even remember the number I selected . Now I can’t even login using my email . Also cannot even get a number .  How do I proceed ?
@members
Racerz2009
Thank you everyone . I was able to get help from the agents . We can close this thread
hairbag1
@Racerz2009
now you'll need help for a Customer Support person to help you activate successfully. Use this link to start the process..
@Racerz2009  Check your sim manger in phone setting and ensure the eSIM is enabled /set to primary and remove old sim and reboot the phone see if that helps . If not you can contact support to help
send  a  private message   To CS_Agent
hi @Racerz2009
check if the esim already instead on your phone and just not enabled.  Check the Sim Manager page or Settings->Cellular.  Enable it or toggle on Turn on this line and Reset Network settings
but if you need PM support agent's help, simply message them
you can submit  ticket by direct message:
