Unable to change credit card.
Chushiyan
When I try to register a new credit card, I cannot click on the card type (Visa, etc). I cannot select any of the input fields to enter the card information. I can type only into the  Postal Code field.
Chushiyan
I spent an hour on this already. I will just wait until my phone service stops working. Then log in to pay. That worked last time I had to change credit card. I wanted to prevent that, but I ended up wasting more time.
@Chushiyan  wait one full hour and try again incognito private mode or even from the new PM app instead or even a different device . If still no luck use this direct link to support to help update it for you
send a  private message   To CS_Agents click
HALIMACS
@Chushiyan
Try after clearing cache and cookies, and using an incognito or private tab.
