03-21-2022 03:47 PM
Hello.
Tried to input a new credit card to make a payment and received this error:
Unable to Process Transaction.
Called my CC and they assured me my CC is working. Last used yesterday. Contacted a Public Mobile Agent who told me it will take up to 72 hours for their tech team to get back to me.
I need to use my phone today and cannot wait 72 hours. I have 2 working credit cards and both of them are not working on Public Mobile's website. Doing a search on this forum, this seems to be an on going issue. Any ideas from the community?
Thanks in advance.
05-14-2022 01:26 PM
Hi @Kirsty911 You have tried using the different options in Payment to make a manual payment?
I think it is probably faster to open ticket with CS Agent and have them check, maybe a Fraud lock there for too many failed attempts
To open ticket with PM , at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-14-2022 01:21 PM
" I read vouchers can come with extra costs added."
Hi @Kirsty911
No extra cost to buy voucher from stores.
it is not convenience but it could be a quick fix for someone who needs the service back quickly
05-14-2022 01:13 PM
Why should we have to? We have working credit cards. Vouchers come with extra charges.
05-14-2022 01:12 PM
Doesn't solve it
05-14-2022 01:11 PM
But the credit card issue has been ongoing for years - and I read vouchers can come with extra costs added. This doesn't seem like a proper solution to me. I've got a working CC; why should I have to do something different?
03-31-2022 03:24 PM - edited 03-31-2022 03:24 PM
@kurenai "it will take up to 72 hours for their tech team to get back to me."
Definitely poor, but a real possibility at PM. This post may have some ideas you could use going forward. https://productioncommunity.publicmobile.ca/t5/Get-Support/100-SERVICE/m-p/183753#M33693%
03-21-2022 06:46 PM
@kurenai wrote:I opened one, they told me up to 72 hours to get tech help. Does that sound reasonable to anyone? I just want to pay and use my phone...
No, it is not reasonable! My experience with agents is reply within 30 min or less. But every agent is different; some are experienced some are new...
Can you get a hold of any vouchers and load them through 611? But then, some vouchers have delay of 24 hours to become active. 😞
03-21-2022 04:18 PM
Some stores like Mobil gas stations do real time payments. Some stores don't know the term voucher. They might be more familiar with cellphone minutes.
03-21-2022 04:17 PM - edited 03-21-2022 04:18 PM
@kurenai by real time payment, it is instant top-up , it does have a fee of $1. YOu just need to provide them your phone number
Instant top-ups are currently available at most Canadian Tire Gas, Esso, Gateway Newstands, and MacEwen locations.
03-21-2022 04:16 PM
Real time payment?
Went to 711 an hour ago and they didn't have Public Mobile Cards/Vouchers.
03-21-2022 04:15 PM
03-21-2022 04:14 PM
So stop stressing over the card and buy a voucher or do real time payment and then figure out the card problem when it's all working again.
03-21-2022 04:12 PM
@kurenai - 72 hours for CSA to respond, hopefully that is sooner.
Since you have tried a few times, I would hold off and wait at least an hour.
Then you can go to the PAYMENT tab and see the bottom, left corner to change/update your payment information.
Although, it sounds like you did this as you mentioned "I decided to Remove it and enter a new CC".
But, I would remove anything there again.
Perhaps log out, and before you try again (after an hour) clear your cache/cookies, or open a tab in incognito mode. You can also try a totally different browser or device.
03-21-2022 04:09 PM
03-21-2022 04:07 PM - edited 03-21-2022 04:07 PM
@kurenai wrote:I copied my address from my account profile page and entered it exactly. Same with the postal code. Tried using all CAPS too as one post suggested but it doesn't work.
@kurenai You might have triggered a fraud lock for entered too many times, Account will lock after 2 attemps. Please open a ticket with PM Support
03-21-2022 04:06 PM
Card address or the profile address from this account? Use the card address. But get a voucher to get working again and deal with the card less stressfully.
03-21-2022 04:04 PM
03-21-2022 03:57 PM
@kurenai not sure if you entered it too many times , it might have triggered a Fraud lock
Open a ticket with PM Support and have them to look into it and maybe add the credit card for you:
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
03-21-2022 03:53 PM
There is no CC on file. I tried to Update it but it wouldn't work so I decided to Remove it and enter a new CC. But that doesn't work either.
03-21-2022 03:52 PM
Have you tried buying vouchers? Then you could make calls and texts again. The address of the card should be the same as what you type in. The postal code only fits 6 numbers. Try not including any unit # in the address.
03-21-2022 03:51 PM - edited 03-21-2022 03:52 PM
You can also load funds to your account using payment vouchers available at 711 type of store, then dial 611.
Try using Recharge.com...or Ding.com.
03-21-2022 03:51 PM
@kurenai So, there is a credit card on the file now?
If so, try this again, Go to Payment->One Time Payment,
use the option "Other (Enter the desired payment amount)" and manually enter the plan amount (do not use Amount Due)
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
See if that works
If it works, check if the button Reactivate current plan is there (I assume your plan is current suspended)
Then logoff from My Account and reboot the phone
