USA calling
Tonytracy
  • Hubby and I are in first month with public. We both have USA Canada package. I have iPhone 11pro he is 11. My phone works great for all features, he is not able to call out. Ends instant. He is on Lte in T-Mobile everything same as mine. He just can’t call out. ??? Text and data works. In USA now. Help?
22 REPLIES 22
hi @GordT
the reason is that Samsung Note 10 Plus is not on PM's VoLTE whitelist.  I would say you are lucky that you received calls.  Supposing you won't get any calls at all.  You need to looking for a new phone.
GordT
Thanks for that. I have done all of the resetting and switching networks with my Samsung note 10plus. No help. Interestingly I was able to make calls while in Nashville and nowhere else. Receiving calls, data and text were never a problem.
I appreciate your advise. So far better than the waste of time with Publics tech support.
hi @GordT
what phone do you have?
this is something that can be fixed  Try Reset network settings, and connect to all 3 different networks in US manually and at least one of them should work.  T-Mobile, AT&T and Verizon
GordT
I have same problem. Able to receive calls and not make them in the USA.  Has to do with his phone. Don't bother with the support the are a waste of time
Tonytracy
Thanks all. Will update when back at home on wifi. Mine totally worked fine. I’m happy with mine  ( he wasn’t impressed no calling on his.) He was able to call USA from Canada no prob.
golfball
Oh yeah the phone definitely needs to be updated. The software version is from 2022 and VoLTE was enabled on Public Mobile in 2023.
@computergeek541  T-Mobile in the US does not have any type of 3g/UMTS/HSPA network.
Yes but they do have 2G in spots and a couple of people on here said the were able to connect with non-VoLTE phones by choosing 3G in the settings, which makes it sound like at least some phones might switch down further?  It was worth a try anyway.
@Tonytracy  For VoLTE to work on PM roaming the ios needs to be at minimum ios16.  A non-VoLTE phone can only connect to T-Mobile's 2G network in the USA because, as @computergeek541 noted, there is no longer any 3G there.  The phone will be fine for voice calls in Canada as 3G has not (yet) been shut down here but for US it needs to be updated.
Tonytracy
Haha, says 6 days to update. I will wait till back in Canada or wifi. At least data and text work for now. Thx
@Tonytracy if it were me I would definitely look to update the OS, could be as simple as that
Tonytracy
Wondering he is 15.5 and hasn’t updated in long while. Now 17 .5.1??
Tonytracy
No not working. started over! Tried airplane mode, then off.  Still no calling. Won’t even go through.
@Tonytracy wrote:
3G then no service. It is now showing its calling but doesn’t go through. Before ended instant. On LTE
@Tonytracy , it seems like the phone that is not working is having issues with VoLTE.  Please confirm the settings using this link.  Toggle airplane mode or reboot phone to establish a new network connect and see if that helps.
https://deviceguides.vodafone.co.uk/apple/iphone-11-ios-16-0/calls-and-contacts/turn-volte-on-or-off...
@Phil_Adelphus wrote:
@Tonytracy   On some phones, usually not iPhone but there are exceptions, there is also a VoLTE toggle as well as the LTE setting.   If you can't find a VoLTE toggle it should be enabled automatically by Public Mobile anyway but try 3G on T-Mobile and see if that works.
golfball
There is no 3G in the United States so that certainly won't work.
Tonytracy
Tonytracy
Yes data roaming on and it’s on LTE other option 3g
Phil_Adelphus
@Tonytracy   Does he have data roaming turned on when making calls (I note that you said data works but some turn it off)?  Make sure also that if there is a VoLTE toggle that it is turned on.
Tonytracy
Tried other networks and  still won’t place call 🤷🏻‍♀️
Tonytracy
Nope. Tried both.
eddieO
@Tonytracy have him try restarting his phone or try turning ON airplane mode and then turning it off
golfball
Is T-Mobile the only network available in the area? I would try turning off automatic network selection in cellular settings and manually selecting AT&T or Verizon if you can.
