03-02-2024 03:28 PM
Howdy,
I'd just like to verify whether Hawaii is included for voice & data in these US plans...
Thanks,
FlutteringBy
03-02-2024 05:14 PM
@HALIMACS, @hTideGnow , @Chalupa_Batman , @Phil_Adelphus thanks so much for your input...
Good to know that Hawaii (not Huewai..😊, sorry hTideGnow) is included....yes Phil_Adelphus, my phone VoLTE capable & enabled so it looks like I'm good to go....in the near future...😊...
FlutteringBy
03-02-2024 03:47 PM
@FlutteringBy Speaking of VoLTE, is your phone (whatever it is!) capable and enabled for VoLTE? If not you will have to drop to T-Mobile's 2G for voice calls to work and I assume Hawaii is included in the April 2 shutdown of T-Mobile's 2G - and that assumes Hawaii still has some 2G. That will leave non-VoLTE phones high and dry although data and text should still work so voip apps can be used for calls instead.
03-02-2024 03:35 PM
@hTideGnow wrote:hi @FlutteringBy Huewai is not on the VoLTE whitelist but it can still use roaming add-on, at least roaming data
For voice, you will have to use T-Mobile 2 network
Dude, he asked if Hawaii was part of the US package. Not about a Huewai phone. 🙂
03-02-2024 03:32 PM
03-02-2024 03:30 PM - edited 03-02-2024 03:31 PM
Yes, Hawaii is included in the US coverage for Public Mobile services, @FlutteringBy
Happy Travels!!!
