10-02-2019 01:46 PM - edited 01-05-2022 07:22 AM
Hey,
I had upgraded my plan to the $60 plan with 2GB of data. Did anyone else find the speed of data in the USA very slow? Sometimes it was fine but other times I couldn't even order an uber because I couldn't get a data connection. I ended up having to buy a USA sim.
Does anyone have some insight as to why it was so bad sometimes and good other times?
10-02-2019 03:25 PM
Maybe that what happened. The phone kept trying to switch next works. I was in LA and in major locations so service was not an issue. Just data.
10-02-2019 03:22 PM - edited 10-02-2019 03:26 PM
I went to Lycamobile which uses Tmobile...also the net work that kept appearing on my phone when I was using my public sim card.
10-02-2019 02:08 PM - edited 10-02-2019 02:09 PM
@Degus222 wrote:Hey,
@Degus222 If the local sim that you purchased used the AT&T or T-Mobile networks that would be alarming. What local US sim did you puchase?
10-02-2019 02:08 PM
@Degus222, the US data component is apparently not throttled. Which provider did you buy service from? Maybe AT&T was not offering good coverage in your area.
10-02-2019 01:51 PM
Coverage should be good for most urban centers through AT& T and T-mobile.
Here is the link for AT&T coverage.
10-02-2019 01:49 PM
Some users have found that manually selecting the best network of either AT&T or T-Mobile to help get optimum service. Depending on which area you happen to be in as well.
