09-08-2022 09:14 PM
I went to the USA...upstate New York. I put 1GB of data as an Add-on. It barely worked for the 3 days there. I know the notification says the USA is "turning down" their 3G network but the USA is their turning off 3G network. Please do not rely on this as I did. T Mobile rep told us there is less than 21% of the USA with access to 3G and it is decreasing daily. They are not repairing or servicing the old 3G network.
09-09-2022 12:32 AM
buy sim US and get your refund for add-ons
open a ticket with PM CS Agent. at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
then click "Contact Us", Then click "Other", then click "Click here to submit a ticket.
Once ticket is submitted, (top right corner envelope icon) periodically for response from CS_Agent
If you have problems submitting a ticket, you can also send a private message to the CS_Agent
09-08-2022 11:25 PM
Yeah I think it is a long time coming, either update the add ons or pull them off altogether, the posts about nightmare experiences with this has increased exponentially
09-08-2022 10:34 PM
@Kimjohnston060 wrote:Hii left the phone automatic. I tried to manually select AT&T but it was also not available. It clearly said " no internet". Couldn't open maps, send it receive an email. Had to rely on open WiFi networks at chain stores like Walmart and Lowe's. Very frustrating.
I had the same issue in WA earlier this summer. The phone would connect to T-Mobile but not AT&T. I had no issues with data so long as I was connected to T-Mobile.
09-08-2022 09:28 PM
@Kimjohnston060 you tried manually connected to T-Mobile as well?
09-08-2022 09:25 PM
09-08-2022 09:17 PM
@Kimjohnston060 Since you got only 1GB roaming data, live is easier for you when you roam in US. You don't need 3G for data , you can connect to AT&T and T-Mobile's LTE network for roaming data.
For both US and Canada, your plan could be a 3G speed plan, but that doesn't mean you cannot use LTE network. You can still use LTE network , just that the speed capped at 3G speed, which mean 3Mbps. Usually, leave your phone Preferred network with Automatic, or 4G/3G/2G and your phone will pickup the LTE network for you
(FYI, the only impact for roaming for the 3G shutdown in US if voice. But you can use T-Mobile 2G network for voice )
