US rooming
Dave7917
Hi, I purchased odd-ons  the US rooming call but still I can not call to the US, it says I do not have enough minutes, can anyone please help me
DDM69
2023-05-24 22_46_45-Canada's First 5G Subscription Phone Service _ Public Mobile.png
dust2dust
Roaming is only for when in the states. You need the 1000 minutes add-on. Maybe support will switch it around for you.
@Handy1- Not really fair to add information that subsequent posts had replied with. Very close timing though so....
@Dave7917  Double check you got the right add on first . Then reboot your phone and connect to T mobile or AT&T
Add if you picked the wrong add on by accident please use this direct link to support to see if they can reverse it for you
send a  private message   To CS_Agents click
DennyCrane
US roaming add-on's are for use IN the US, not for use in Canada. To call the US from Canada you'll need a US Long Distance add-on.
