09-01-2023 02:38 PM
Hi,
I am having issue accessing my account, it keep taking me to the "Resume Activation" page and when I click it and try to log in, it say my email and password does not match. I've already purchased a plan. Please help.
09-01-2023 02:47 PM
HI @genji
you have service with PM and try to login ? or you are activating?
if you have service with PM and unable to login , you need to submit a ticket with CS agent here:
if you are trying to activate, then try using the app. Uninstall and reinstall the app and try again
09-01-2023 02:39 PM - edited 09-01-2023 02:40 PM
Hello! You must complete the activation with the app. Download the app and login when promoted upon opening the app and you should be able to continue your activation.
09-01-2023 02:39 PM
@genji Have you downloaded the app to finish the activation .try that if you haven’t already . If no luck please use this direct link to support to help
send a private message To CS_Agents click
VVVVV Link below VVVVV
