07-27-2021 09:32 PM - edited 01-06-2022 02:55 AM
Hello! I purchased the 10 day US bundle with data, talk, and text. Every time I try to send a text or call I get a message that 'sorry, your plan does not include sending texts while in the US. Incoming texts are included.' I turned on data roaming on my Samsung S7. I've turned the phone off and on a bunch of times. Under mobile networks I have the access point names Mobile Internet, Public Mobile, and Tethered Mobile Internet. The network operator says AT&T. Any suggestions? Thanks!
| US Roaming - 250 MB Data (10-day) |
| US Roaming - Unlimited Talk (10-day) |
| US Roaming - Unlimited Text (10-day) |
07-29-2021 09:55 AM
thanks @softech for the tip to stop in with one of those carriers.
07-29-2021 09:53 AM
@ccgibbs ok. let's hope it will end well.
how long more you are in the States? Remember it might be cheaper to get local Data SIM , especially if you are still there for awhile. You do give up the beauty of text and calls with your PM number.. but you can use app like TextNow and give your friend the temporary number.
Another suggestions, if you see a TMobile or ATT store, pop in and see if they can assist. Yes, they are sales, but sometimes you might bump into a nice one and might help.
07-29-2021 09:44 AM
No @softech it still isn't working but the moderator is trying to help. Thanks for your help.
07-29-2021 09:33 AM - edited 07-29-2021 09:33 AM
@ccgibbs see you online now.. how was it in the end? were you able to get everything working or you opened ticket and mod helped you?
07-28-2021 12:30 AM
@Seetharian wrote:Have you gone into your setting on your phone and turned on cellular data or roaming? Sometimes its just a setting in the phone that's the problem.
@ccgibbs's data is working. Talk and text aren't working. There's no roaming settings for talk and text.
07-27-2021 11:55 PM
@ccgibbs : Can you click on Plan Details on the overview page and maybe post a screenshot. Blank out personal info of course.
07-27-2021 10:59 PM - edited 07-27-2021 10:59 PM
@ccgibbs To get to open a ticket with mod.. at chatbot
just type this: Data troubleshooting
then pick "still not working"
pick "android"
pick "click here to submit a ticket"
Another page will open and you can open a ticket there.
07-27-2021 10:55 PM
07-27-2021 10:52 PM
When I try and open I ticket I get to the chatbot and then to this forum. I can't figure out how to start a ticket.
07-27-2021 10:47 PM
Thanks, tried that and no change. My data seems to be working, but I can't call or text even though I have it as an add-on.
07-27-2021 10:42 PM - edited 07-27-2021 10:45 PM
@ccgibbs when did you buy the US roaming package?
also try this.. Toggle airplane mode on, wait a few minutes and then toggle off
I think we have tried everything covered in this KB article..
U.S. Roaming - Community (publicmobile.ca)
maybe the next thing is to open ticket with Mod..
07-27-2021 10:35 PM
I cannot get it to work with AT&T or T-mobile
07-27-2021 10:32 PM
07-27-2021 10:21 PM
Thanks. I can't get it to work with AT&T.
07-27-2021 10:21 PM
Is there perhaps a problem with the access point name? I have mobile internet, public mobile, and tethered mobile internet.
07-27-2021 10:14 PM
AT&T should have better coverage in Iowa.. but you will tell us your experience..
07-27-2021 10:10 PM
Iowa City, Iowa
07-27-2021 10:10 PM
I am in a city and have all bars
07-27-2021 10:10 PM
@ccgibbs which states and city you are at?
07-27-2021 10:10 PM
No none of those are working
07-27-2021 10:09 PM
@ccgibbs : Sorry. Yes. You said that. Let it keep spinning. It could take a short while to pick up networks. Did you have any bars?
07-27-2021 10:08 PM
OK wait it finally found some networks. Tried T-mobile and nothing worked. Will try AT&T.
07-27-2021 10:05 PM
android samsung s7
07-27-2021 10:05 PM
Sorry I missed the steps at the bottom! When I search for networks it just spins and nothing comes up
07-27-2021 10:05 PM
@ccgibbs : Do you have an iOS or Android phone?
07-27-2021 10:04 PM
I'm not sure how to connect to T-mobile
07-27-2021 10:01 PM - edited 07-27-2021 10:04 PM
@ccgibbs you can try both T-Mobile or AT&T and see which one is working well for you. Also, is the data working?
07-27-2021 10:01 PM
OK I can try and figure out how to do that
07-27-2021 10:00 PM
Thanks. I tried the chatbot and it sent me to this forum. I suppose I can try the second method. Thanks.
07-27-2021 09:59 PM
@ccgibbs : Do you have a decent signal reception? You could try to manually connect to T-Mobile too rather than AT&T.
