03-22-2024 07:21 PM
With a plan that includes US data, are there any limits on long-term usage in the US? For example, a snowbird spending 6 months of winter down in Florida would be fine?
03-22-2024 07:54 PM
as long as your PM account is paid up, you'll be able to use it for as long as you like. We can't find any "fine print" that suggests otherwise.
03-22-2024 07:23 PM
HI @PostAlone
there is no terms we can find saying the maximum data you can use in US, so technically you can use them all in US without worries.
