US roaming ( TEXTING NOT WORKING)
hoyer
I am roaming in the us and the talk feature is working but the texting is not.
@hoyer  - are you iphone (ensure your data is enabled if you are using iMessage) or android?
Yummy
Did you buy proper add-on? Did SMS ever worked whit whatever add-on you bought?
US ROAMING ADD-ONS
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
 @hoyer : Click on the Plan details link and report back what all is listed. Or do a screenshot of the lower area showing all the items.
darlicious
@hoyer
Double check the US roaming add on you purchased. Incoming text messages should work regardless if you have a roaming add on. Reboot your phone and manually select at&t or T-Mobile. Try sending yourself a text to test the service.
@hoyer   which Roaming package did you buy?  TAlk/Text? or Talk/Text/Data?
if the one you got has Text in it, try to connect to another carrier you are connecting to (ATT  or T-Mobile) and see if it works good
Of course, try one more reboot
