US calling
Bobccat
I have 500min INTL Long Distance including CA & US. Does this mean I can call from the US to Canada for up to 500 minuets?
8 REPLIES 8
Yummy
No. PM plans works while in Canada only.
To call from US you need to buy appropriate add-on
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
HI @Bobccat   Yeah, if you can get a friend with a landline, mobile line that can help you to setup Google Voice, get one, it is very useful long term. Easy to call Canada/US for free  🙂
Zyl
@Bobccat   Or call from any of the online chat app like skype or wechat.  And since you will be in USA, you might even be able to apply for an account with Google Hangout and place calls using Hangout.
Happy traveling in the USA!
HI @Bobccat   to call from US to Canada, you need US Roaming addon
Or if you want some free solution, download VoIP app.  Some good choices are Fongo or TextNow.
@Bobccat
Nope only in Canada…need to purchase roaming add-ons to calling from USA.
VIP_Tech
Hi @Bobccat
No only in Canada call to U.S.
out Canada you need to Purchase Add-Ons through Self Serve (publicmobile.ca)
for service in U.S. Roaming (publicmobile.ca)
@Bobccat
Just reverse it...you can call while in Canada to a number in the USA for 500 minutes. 🙂
In order to use any services in the USA you will need to purchase Roaming Addons either through your self serve account or by calling 611.
CountyDownIeUk
No.  That add on is for use while in Canada.
