04-18-2023
11:43 PM
04-19-2023
12:52 AM
computergeek541
04-19-2023 10:03 AM
Do you know if your phone has been enabled for volte? What is the make and model? Does real sms texting work? Can you set networks to 2G?
04-19-2023 09:59 AM
Yes , 15 day US roaming addon. Data working, not calling.
04-19-2023 02:13 AM
@pwherr wrote:I'm unable to make calls within US, or back to Canada with my US addon.
US long distance add-on can't be used in US. For US roaming add-on, do you have 2G signal?
04-19-2023 12:15 AM
Is this a re-buy of the same add-on?
04-18-2023 11:49 PM - edited 04-18-2023 11:50 PM
make certain Roaming Data is enabled in settings.
You can only connect to T-Mobile...no others will work with your PM roaming add-on.
added...you did get the 15 Day US Roaming add-on...right ??
