07-19-2026 09:09 PM
I’m switching my phone from Bell Aliant to Public Mobile.
I’ve completed the payment and installed the eSIM. I also replied “YES” to the Bell Aliant text authorizing the transfer.
The phone connects to the Public Mobile network, and my mobile data is working.
However, my phone number is not being recognized for iMessage, and texting and calling only work when the old Bell Aliant SIM is enabled.
I’ve also tried deleting the original Public Mobile eSIM, purchasing a new eSIM, and setting it up again, but the issue remains.
07-19-2026 09:44 PM
hi @Jeremyreeve
tell us if the old one is physical sim card or esim?
and tell us if the PM sim is physical or esim?
and only put the PM sim in the phone (if you have esim, disable the old one, only PM is the enabled one, and set the label to Primary), then reboot your phone and reset network settings. Test and tell us if outbound calls work, if inbound calls work, and if mobile data works
07-19-2026 09:37 PM
It is a cellular. Number
07-19-2026 09:37 PM
Yes only when both sim
cards are installed
07-19-2026 09:21 PM
HI @Jeremyreeve
is your Bell Aliant a mobile line or land line?
if it is land line, it take 3 to 7 days. So, until the port is done, you won't be able to use iMessage
07-19-2026 09:11 PM
can you receive incoming calls?
