US Roaming
10-12-2023 02:26 PM
I have paid 3 different times for US roaming and each time I've been in the U.S., my phone won't work. Any suggestions as to why?
Add-Ons
10-21-2023 01:03 PM
That is correct, unfortunately your phone doesn’t have VoLTE. So next time you are in the US you will have to manually connect to T-Mobile in order for your calling to work and make sure you have data roaming turned on if you purchased a data roaming add-on.
10-21-2023 08:53 AM
Thanks everyone. My phone is a Samsung A8, so I'm guessing it doesn't have VoLTE. Thanks for all your help.
10-12-2023 10:13 PM
1) Make sure to go into your network connections and turn on Data Roaming
2) Go into your network settings and set your Preferred Network to 4G vs 5G.
3) Try changing your phone to manual network selection and choose T-Mobile vs AT&T.
And as has already been asked, what specific add on did you buy? And what phone are you using? So all services not work (calls/text/data), or just certain services?
10-12-2023 02:36 PM
hi @Linda52
so, you are back in Canada now?
Which roaming add-ons you got?
if you are still in US, can you try to manually connect to T-Mobile and AT&T. One of them should work. And depends on voice or data, you might need to do different things to make it works, liike Enable Mobile Roamding data on your phone for data, or changing to 2G on T-Mobile for voices to work
if you are back in Canada, try to submit a ticket with CS Agent, they might be able to do something:
10-12-2023 02:28 PM - edited 10-12-2023 02:30 PM
Which specific add-on have you been purchasing?
If it’s a data add-on ensure that you have data roaming turned on.
You will need to connect to either AT&T or T-Mobile. If one doesn’t work please manually connect to the other and reboot your phone.
If your phone isn’t VoLTE enabled you will need to manually connect to T-Mobile and put you voice and data settings to 2G GSM in order to have calling work. You can check if you have VoLTE support on your device from Public Mobile here:
