01-21-2023
12:10 AM
01-21-2023
10:32 AM
Dunkman
I am in the US and have already added the unlimited US Call and Text roaming add on. I am able to send SMS but I am unable to make phone calls to any number. It just tries to connect but never does.
01-23-2023 03:24 PM
Location, location, location. Where were you when you attempted to make a voice call? Unless you were in an urban area there was likely no network to connect to? All 3 of those states have poor coverage both the 2G network and when it existed the 3G network. Even the 4G LTE network has its limits in those states but texting can work with a weak signal since it only needs the briefest of connections to be sent and recieved. Customers need to lower their expectations with Roaming add ons in rural areas of the US especially in the west. It doesn't matter which provider you have there are areas that simply do not have coverage.If that's ones expectation then utilizing a satellite phone would be a better choice.
01-23-2023 12:24 PM
please open ticket with PM Support. The understand the roaming situation and usually will provide full or partial refund without problem
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
01-23-2023 09:53 AM
Thanks @softech I'm travelling around so I have been in Washington, Utah, Colorado. What would be the best way to get in contact with PM to get that refund. I didn't notice that it wasn't working as I was using SMS most of the time, until I got stuck and needed to call someone and realized it does not work.
01-21-2023 11:23 PM
Lol...you made me look! There are large sections of New York City with no 2G network. If you look at Manhattan there is basically no service on the east side and Central Park but good pockets of service on the west side its almost literally black and white in comparison.
01-21-2023 11:11 PM
Florida does have poor 2G network coverage. NYC is probably due to the density of highrises affecting 2G signal penetration and interfering with its ability to transmit over longer distances.
01-21-2023 10:58 PM
@darlicious wrote:Your ability to connect to T-Mobile's 2G network is dependent on your location. It is much easier on the eastern side of the US as the network is much more comprehensive
@darlicious but surprisingly, sound like 2G Talk are not working very well in NYC and Florida 🙂
01-21-2023 10:32 PM
Your ability to connect to T-Mobile's 2G network is dependent on your location. It is much easier on the eastern side of the US as the network is much more comprehensive than in the west where it is mostly in urban or heavily populated areas. Use the link supplied by @softech to my thread and check the updated post for access to the cell mapper link. That interactive coverage map will allow you to check your local area for cell towers transmitting a 2G network signal.
01-21-2023 01:22 AM
What make and model of phone? It might be that your phone isn't able to switch down to the old 2G/GSM automatically and also that it might not have the choice to set it manually.
01-21-2023 01:14 AM
Just go to your cellular network settings and connect to T-Mobile.
01-21-2023 12:12 AM - edited 01-21-2023 12:15 AM
@justindra US roaming Talk is a bit ticky now. US has decommissioned 3G network and PM is not using voLTE , so we are relying on T-Mobile's 2G network. Problem is that the 2G network is old and unreliable
Which state and city you are at?
try to change the preferred network to 2G and see if the phone connects and able to make calls
If not, check around different area in the city. But again, it might or might not work
Worst case, PM will refund the cost of the roaming
Add: For your best interst 🙂 , check this great thread with the background and current situation about US roaming Talk (prepared by @darlicious):
