US Canada plan
dynamite
I'm in the Us and have texting but can't make calls. Not connecting
Sawrie1
Do you have the $65 unlimited is can package if not dial 611 to buy minutes in the US.
Phil_Adelphus
@dynamite   If you don't know if your phone has VoLTE can you tell us what phone you have.  If your phone is set to 5G try changing that to 4G/LTE.   If your phone is not VoLTE capable/enabled, then try setting it at 2G and connecting to T-Mobile.  The USA no longer has a 3G network so phones that are not VoLTE (voice over LTE) will only be able to make calls on T-Mobile's 2G network which can be hit and miss depending where you are.
@dynamite  Does your phone have voLTE and make air e you connect to T mobile or AT&T
