01-10-2023 08:58 PM - edited 01-10-2023 09:17 PM
Hey community,
I was browsing the latest plan changes and noticed that the US roaming add-ons were just increased in service, time, and price, with talk-only and 500MB being delisted. Hopefully it's good news for most customers.
Was
10 days
Now
15 days
01-11-2023 09:58 PM
Hi all,
I can confirm that last month while in Palm Springs and using PM’s $20 talk/text/data add-on, my phone (iPhone XR on iOS 16.2) would automatically switch down to 2G whenever on incoming call came in. Same thing when making a call. Even there was no option in settings to manually change to 2G (only LTE and 3G).
Hope this helps.
01-11-2023 09:29 PM
I will let this forum know what I find out!😊
01-11-2023 08:47 PM
Well the majority of his route is saturated with 2G towers. I even found a few towers with 850Mhz among the mix of towers using the 1900Mhz band.
01-11-2023 08:44 PM
@darlicious- It may be. We just need more people with iphones that are a bit on the enthusiast side of things to try things out. Not the ones "it doesn't work I want my money back NOW!" types. 🙂 Maybe Rick72 will be able to sort it out for us with his findings. If he finds himself in a major metropolitan area with 2G galore and his phone simply refuses to dial even 611 then we'll have more evidence.
01-11-2023 08:27 PM
I think it's going to be a similar issue to @DennyCrane 's pixel 5 issue not allowing 2G to be selected or even found?!!
01-11-2023 08:24 PM
T-Mobile has excellent coverage on the eastern seaboard including the 2G network if you are able to connect to it. Only parts of Maine and West Virginia have poor coverage. You should try this workaround for a test....download textnow and choose a Canadian phone #. Call forward your pm phone # to your textnow phone # for busy/unreachable. Your calls should ring thru to your textnow app on your phone if you cannot connect to the 2G network. You can use textnow for your outgoing calling as well. It works on wifi or mobile data.
Additional info on US Roaming can be found here.....
Be sure to read the recently updated post it also includes a link to the cell mapper cell tower coverage interactive map that can give you precise cell tower network coverage.
01-11-2023 07:04 PM - edited 01-11-2023 07:06 PM
@darlicious- I still split the concept. There's whether the option can be selected. Then there's whether the phone will in fact drop down. None of your discussions make a claim that it won't drop down. Maybe it's implied, which is what I think you're hanging on to. But it's not clear.
Adding - @Rick72 - other than the usual out of range areas that happens with all carriers, you should still be fine with data and text. Talk is where the challenge is with the much lesser coverage of their old 2G.
01-11-2023 07:03 PM
@dust2dust I think I will try the US Roaming add-on and hope for the best. I gather the iPhone 12 will be looking for 4G and as we are travelling from here to Georgia my guess is that most of that area will be getting 4G coverage. T Mobile 4G coverage map
01-11-2023 06:22 PM
I have gleaned that info from the following discussions...
https://discussions.apple.com/thread/252630982
However there is a mention in this discussion that it's disabled by the carrier and an iPhone user puts a T-Mobile Sim card in the phone to be given the ability to chose either 3G or 2G so perhaps T-Mobile still offers this option to select 2G under this scenario but it may be disabled by pm since telus decommissioned their 2G network years ago? If @Rick72 has access to a T-Mobile Sim card maybe it's possible or with a Roam or possibly a freedom Sim card?
https://www.reddit.com/r/iphone/comments/xf4rpb/so_apparently_on_ios_16_i_cannot_chose_3g2g/
01-11-2023 05:26 PM
I have iOS 16.1.2.
01-11-2023 05:16 PM
@darlicious- I interpret your document as talking about manually choosing 2G (or 3G) as an option. I don't see where it says it won't drop down automatically.
01-11-2023 05:07 PM
What iOS are you running? You could have an issue with connecting with the 2G network automatically if the 4G LTE network is available and your iPhone is connected to it. Depending on your iOS version Apple may have removed the ability to manually choose the 3G or 2G network.
According to Apple support forums and the following article the iPhone 12 has an extremely limited parameter that will allow it to connect to the 2G network.
https://shudhtech.blogspot.com/2020/12/no-3g2g-option-in-iphone-12-pro-solved.html
01-11-2023 04:47 PM
@Rick72- The phone will do it itself. When a call comes in it will switch down. When you press the go button in the dialer it will switch down. You generally shouldn't have to switch it manually even if you have the option.
Just be sure you're only connected to T-Mobile.
01-11-2023 04:43 PM
I am reading how roaming in US requires 2G for voice services but how can I change my iPhone 12 cellular settings to 2G? The only options are LTE and 4G.
01-11-2023 11:16 AM
I don't know why there is this consensus that public mobile's US Roaming add ons are unreliable. While voice services are dependent on the 2G network which has significantly better coverage on the eastern side of the US than the west if a customer does a little research on their travel route and destination (s) they can determine their likelihood of 2G connectivity. As far as roaming data and text is concerned they will have the same coverage as 110 million T-Mobile subscribers to say that ....that many Americans have unreliable mobile services is irresponsible. The majority of issues that pm customers have with US Roaming add ons when you remove current issue with voice services stems from the customer not taking the time to learn the basics on how they work.
01-11-2023 10:38 AM
@esjliv That's true. It wouldn't be good to be out that kind of money for no roaming service.
01-11-2023 09:44 AM
@mitchnet12 - if service becomes more reliable for roaming...then IMO that would be the good news.
Here is hoping this is where things are leading to...🤞
01-10-2023 09:28 PM - edited 01-10-2023 09:28 PM
HI@darlicious nvm... i was wrong 🙂
01-10-2023 09:22 PM - edited 01-10-2023 09:23 PM
01-10-2023 09:14 PM - edited 01-10-2023 09:16 PM
HI @darlicious it wasn't searchable because it was in Lounge
would be ok you put it in get help section. It should not be a lounge topic
do you need me to ask a question "how to use Roaming without 3G" so you can reply in Get Help section? LoL
(but I hope some member won't reply in 15 seconds telling me to ticket with PM support. lately, we have member who jumps on reply without thinking 🙂 )
01-10-2023 09:13 PM
@darlicious I'm glad you're always looking out for the customer
01-10-2023 09:11 PM
True had I started a new thread rather than just updating the current one would have allowed for it to appear in a search with a different title.
01-10-2023 09:08 PM
@hTideGnow I agree. It's a bit more to do a short trip.
01-10-2023 09:05 PM
Hi @mitchnet12 overall, I think 15 days is a good move, but would be nice if they have a small bundle, talk/text/1GB, even for $25
01-10-2023 09:04 PM
@darlicious I shouldn't be surprised that is was already noticed. I tried searching the forum but your thread didn't show up.
01-10-2023 09:02 PM
The US Roaming add ons were changed late last week as you may have noted when you read my update to my thread on US Roaming add ons earlier today.
