UK roaming : I plan on travelling to UK for 10 days. Is there roaming package i could activate ?
07-22-2024 09:36 AM
I plan on travelling to UK for 10 days. Is there roaming package i could activate for this duration ?
There is a 500 mins international calls active in my account however i believe this is just from within canada, is that right ?
Add-Ons
07-22-2024 12:50 PM
I used giffgaff. They mailed a free SIM card to me in Canada. So, I was able to set up an account and have coverage when I got off the plane; no searching airport or strange mall for a retailer. Unlimited calls and texts, 5G speed, at $8-15, depending on data required. Has EU roaming, too.
07-22-2024 10:18 AM
The 500 minutes LD calling can only work if you make the call while in Canada not in the UK.
07-22-2024 10:11 AM
Depending on your needs you can pick up a local sim and provider or use apps like textnow or WhatsApp if wifi is available.
07-22-2024 09:47 AM
PM has no roaming in UK. But if you travel for 10 days in UK, it is best to use the travel esim if your phone takes esim. I can provide you some info
07-22-2024 09:41 AM - edited 07-22-2024 09:41 AM
@Trup_18 Public Mobile only offers roaming to the US, you would need to get a local SIM card for any other location. You are correct, the 500 mins can only be used from within Canada
