US package
Eileen27
Can I get a daily package when travelling from Canada to the US that only charges me IF I use the package, and only on the days I use it? All I can find are 15 day packages that are $15 a day. @members
Godzillaz
Its prepay system so need to buy before you roam
Now in practise I DO receive text messages while roaming in USA that say reply to add a roaming plan but it is easier and safer to add prior to trip
The addons will expire whether you use them or not
So you could wait until in USA to add but if issues you get stuck that way
kb_mv
@Eileen27 The 15 day US roaming packages are NOT $15 per day. The price you see is the price for all 15 days use. It starts as soon as you buy it so wait until you are there or almost there.
hi @Eileen27
sorry, no daily package.  Plus that will be more expensive
best to choose Canada/US/Mexico plan, starts at $29 and much better value
for choose one of the US roaming addon , the Bundle (data/talk/text) is $30 for 15 days, but Talk and Text is slightly cheaper
