UK Options?
Rspellz21
Hi - I'm new to PM, and am planning a trip to England. Are there any coverage options (2-week stay) available?
Flyingfinn1982
Best to get a Sim in the UK from Vodaphone or Orange. Public won’t roam in the UK.
@Rspellz21  Maybe for this trip , but you made WISE choice  of choosing Public mobile for long term savings in my opinion , enjoy your trip @Rspellz21
@Rspellz21 sorry, PM has no service in UK
Check with local  data sim, they are great and cheap.  I used Lebara before , price is good
or check eSIM solution if yours support eSIM   Airalo is one that is popular
Rspellz21
@Handy1 thanks. Good to know. Perhaps I should have stayed with my old provider for a couple extra weeks.
dust2dust
Not from here. TextNow or voip apps work well though when connected to the internet somehow whether via wifi or local cell data. You can forward calls to that number and even with some techy work forward texts. Don't let the forwarded sim connect to a US tower on the way.
@Rspellz21  Sorry pM only works in Canada and the US with US roaming add ons , best to get local pre paid SIM card for your trip
