Re: subscribing
Jenny0101
I have the same problem.  As soon as I log in the $39 offer is gone.
Also I can’t find any options to activate a second line for my family.
help!
@Jenny0101
Remember to make a note of the new email and password then keep it somewhere so you can remember so you can login to the account.
hi @Jenny0101
you will then have to manage on behalf for them. You will create another email (maybe Gmail) for yourself.  Then use that new email according to create the new PM account using your name (you don't need to use your kid's name for this new PM account.  In fact, since you are managing it for your kid, it is better to use your name for this new PM account, it will be eaiser when you open ticket with PM support for this account in the future)
Jenny0101
And if it’s for a child, how to make a new account?  They’re too young to have their own email.
Phil_Adelphus
@Jenny0101  Also I can’t find any options to activate a second line for my family.
It's one line per account, each account is separate and needs a different email address to set it up.  There are no family plans with Public Mobile so you would need to set up another account for the other line.
