Dominican Vacation
tacoma_01
im traveling from Canada to the Dominican Republic, Are there any options or add on plan's to be able to use my phone while there
@tacoma_01 problem with WhatsApp is it only work if the other party has it.  For true free calls and text, use VoIP app.  Some good ones are Textnow and Fongo
@tacoma_01
Use WhatsApp when connected to wifi for free calling and texting.
kb_mv
@tacoma_01 To add on to what @DDM69  posted, look at a company like Airalo or Ubigi. I have used both successfully in the past (assuming your phone can use esim).
DDM69
I use an ESIM when travelling.  Cheap data and easy to download and set up.  Public has no service in the Dominican.
Public Mobile doesn't offer any service there.  You'll have to use a combination of Wi-Fi or service from another company for your communications.
