05-15-2022 10:51 AM
Bell is saying the phone is locked under public mobile. Can some help me out
Phones
05-15-2022 01:46 PM
Public Mobile can unlock the phone for you but you need the IMEI # to give customer support. Have the buyer give you the IMEI # by dialing *#06# on the iPhone and the CSA agent will get Apple to unlock the phone.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-15-2022 12:16 PM
They will need to bring it into a Telus store to have it unlocked for free or a mom & pop cell repair store to have it unlocked.
At the Telus store, they will need your mother’s Telus account number to have it unlocked.
Good luck!
05-15-2022 12:01 PM
Just have to get the unlock code from Telus (or Telus owned providers) I am assuming the person you sold it to is a little p1ssed at this time?
05-15-2022 11:15 AM
@LeciaroverRTK Yes, PM will unlock for Telus
05-15-2022 11:12 AM
HI @LeciaroverRTK Technically if the phone you got was from Telus, you should ask them
But with PM owned by Telus, you can try to open ticket with them. At : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
05-15-2022 11:07 AM
The phone started with Telus then was switched to koodo
05-15-2022 11:06 AM
Where did you buy the 6s? If Koodo or Telus contract then it is locked to Telus.
05-15-2022 11:04 AM
But that sim is in my mothers new phone
05-15-2022 11:00 AM
I got her an iPhone 8 and we just pop the sim out iPhone 6s and put it in the 8. I sold the iPhone 6s to someone. And they can’t get it to with bell. Just wondering would the phone be locked on public moblie
05-15-2022 10:59 AM
Old phone, new phone; phone does not matter.
Both accounts have to be active and you initiate porting at Bell. Leave PM SIM in the phone, answer Yes at porting authorization SMS within 90 minutes.
05-15-2022 10:58 AM
@LeciaroverRTK wrote:My mother was using this phone and I upgraded her phone. She still with public just as a newer phone. So the old phone is doesn’t have an account too it. I don’t think it would
Are you saying you switch phone numbers on your mother's account? If you did that then the old number will be lost.
05-15-2022 10:56 AM
05-15-2022 10:54 AM - edited 05-15-2022 10:57 AM
@LeciaroverRTK , in order for you to transfer your number out, you need to make sure the account is active and you have to acknowledge the number transfer out. See link below.
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
