Trying to get information.
LiamCer
I have a PEI public mobile number.
I’m in Reno on business.
I bought the Canada-US 50 GB plan.
When I bought it, it now says Canada only.
So I bought the Canada-US plan again.
But now it still doesn't work.
How can I get help setting this up right or getting a refund? I can't submit a ticket. It freezes.
7 REPLIES 7
@LiamCer I bought one then the other. Need a refund.
You would need to contact customer support if you want to make a case for a refund, we are only customers here in the community.  If you can't open a ticket via the chat icon bottom right of this page then use the private messaging link @eddieO gave you.  You must be logged in to this community for it to work.
LiamCer
Yes. That is mine.
LiamCer
LiamCer
I did have roaming off. I think that fixed it.
eddieO
@LiamCer to confirm which plan you are on go into you Public Mobile app, the first tab is "Subscription" and there is a spot that says "Manage Subscription", go into that. It should look similar to mine:
Phil_Adelphus
@LiamCer   There are two $34 50GB plans, one is Canada-US and the other is Canada-only with unlimited data, is it at all possible you accidentally picked the wrong one?  If not, is anything working?  If you have a non-VoLTE phone data and texting should still work but voice calls are iffy unless you can connect to T-Mobile's 2G network (there is no more 3G in the USA).
eddieO
@LiamCer, do you have you data roaming turn on? Depending on what phone you have you may want to keep it on 4G while in the US so that your phone can work with AT& or T-Mobile. If your phone is on the Public Mobile whitelist for VoLTE devices then you should be able to call on either but if you are having issues with making/receiving calls you will want to lock onto T-Mobile for calls.
As for the refund, you will need to contact a CS_agent:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
