04-03-2024 10:44 AM
Ok went through the step but used omen my current sim is on and won’t activate didn’t relized need to to do in the free imei and go to support login and all I get is a white screen won’t load anything tried login out everything help
04-03-2024 11:30 AM
04-03-2024 11:13 AM
Yes
04-03-2024 11:12 AM
Are you using the PM app to activate your SIM? You need the app to activate SIM and not online.
04-03-2024 10:46 AM
@Jasono46 Try this sorry link for support instead then
send a private message To CS_Agents
