04-01-2024 07:09 PM
04-03-2024 11:31 AM
tried this didn't work
04-02-2024 12:15 AM
You can try these new APN settings:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
04-01-2024 07:13 PM
@DAISY1V0 Are you using an Android phone? If yes, check your APN settings. Make sure you have data turned on in order to send and receive MMS messages.
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
04-01-2024 07:11 PM
@DAISY1V0 If you have older phone from 2015 you may need to try a network reset to get the new APN settings . But PM announced that the older phones would not be supported for MMS . Going forward
