09-20-2024
10:15 PM
09-20-2024
10:31 PM
computergeek541
how many times does one need to trust a device before it's fully trusted?
09-21-2024 01:03 AM - edited 09-21-2024 01:04 AM
Based on my experience, if you login on trusted devices through the same wifi, it will work on your next login but if you use public wifi. You will need to enter the 2FA code before you can access your account.
09-20-2024 11:28 PM
I use the app on my cell phone and I never have to log in.
09-20-2024 11:27 PM - edited 09-27-2024 12:27 AM
@eddieO for the app on the phone, it is stills using your default browser for login. So, make sure your default browser on your phone does not have the clear browser on exit enabled
09-20-2024 11:20 PM
@PMAC0000, on my computer visiting the PM website it seems to remember my trusted device setting but on my cell phone it will not regardless of how many times to place a checkmark on it so it doesn't seem to work perfectly in all cases
09-20-2024 10:27 PM - edited 09-20-2024 10:28 PM
@PMAC0000 did you set your browser to clear cache on exit? or maybe it is set as default? To assure the trusted devise works, please check the settings and make sure it is not set that way
