SIM card
Mi15
Updating my device, do I need to get a new SIM card?
2 REPLIES 2
Mi15
Thank you.
@Mi15  No just take the sim card out of the old phone and put it in the.new phone that’s it , and if your SIM card appears to big for the new phones sim tray just snap the outer edge of the sim card for proper size . And you will keep same phone number and plan no worries
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
