08-30-2019 08:19 AM - edited 01-05-2022 06:45 AM
Hi there,
I have a Bell pre-paid number that I tried to port over to Public Mobile. I am already a Public Mobile customer and had a number/account with them.
I clicked on the "Change Number" link and selected "Transfer a wireless number from another provider" and put in the Bell pre-paid phone number and my Bell account number. I wasn't able to get the SN number from my phone and don't have a PIN with Bell so I left those blank. But it still went through and it said the change was made successfully.
However, when I call the Bell number, my Bell phone is ringing. And when I call my old PM number, it says the number is not in service!
Please help!
08-30-2019 08:29 AM
It's working! Took about half an hour 🙂
08-30-2019 08:26 AM
@Micktedluna wrote:Hi there,
Please help!
Give it a bit more time, it will work if you used the correct account number of your 'ACTIVE' Bell Prepaid Line.
Also there is no such thing as a SN number in the wireless porting world. You just need only 'ONE' of the following three things
1) Account Number or
2) IMEI of the Device that had your Previous Active Sim Card or
3) Account Pin /Password
Remember just one not all three
08-30-2019 08:23 AM - edited 08-30-2019 08:25 AM
Has it been over 2 hours since you ported ?
You should contact a moderator.
Moserator can be reached at
08-30-2019 08:22 AM
@Micktedluna porting usually takes a few hours. How long ago Did you port it over? Restart your public mobile phone also
