Travelling
Duder531
I'm travelling to BC Interior next week from southern Alberta. This is my first time leaving my coverage area for another province. What do I need to do to maintain my phone and data coverage as I travel?
10 REPLIES 10
@Duder531
PM is Canada wide calling and texting.
My friend recently travelled from Vancouver to Toronto on the $15 plan. The only issue was getting data, he could only get WiFi at train stations stops.
@Duder531 wrote:
Thx Yummy. I thought PM only worked in your home province, that you need to buy an add-on if you travel. Am I wrong on that? Also, should I leave roaming in or off while traveling?
@Duder531 roaming is for outside of Canada.
As for the setting on your phone I would suggest you keep Roaming on (perhaps living near a US boarder town may ping US towers, but in this case you can manually select public as your network provider), there are no charges for Roaming as you won't get charged for something you did not already pay for here at public, due to being paid.
@Duder531  No need to change a thing leave your phone settings the way  you have them now . And enjoy your trip 🙂
Mojo7
Public mobile works off of Telus towers which can be found in BC. If you go to your account and check out your plan it should say Canada wide. Meaning there will be no extra charges. You should have no problem using the same services that you use while in your own province.
LitlLdy
@Duder531 , you could go in your Settings, Cellular, Network Selection set it to Public Mobile not Automatic. I don’t think it is necessary though. You shouldn’t have any issues.
Duder531
@Duder531
your data will work national-wide
your voice should, too, unless you are on a Provincial calling plan
Yummy
Nothing if you have Canada wide plan.
Your phone should work wherever you are in Canada (but it will depend on cell towers in your vicinity).
@Duder531  Nothing your phone and plan should work all across Canada like you were Still at home
